Oil Gauge is bobbing and drops to 0% in idle
Old 01-19-2009, 03:27 PM
AEChevy's Avatar
AEChevy is an unknown quantity at this point
Default Oil Gauge is bobbing and drops to 0% in idle
Ok I dont know whats going on now lol
Yesterday my brother and I popped off the carb and replaced the gasket. Boy was it a mess, there was a 2 inch gap where air was getting in. Started the truck and it ran fine. Beautifully in fact.
I left the truck over night and drove it this morning into town. Everything seemed normal until I slowed to an idle and then the oil gauge needle started bobbing up and down. Then dropped to 0%. But onceI start up again and get rolling, it goes up to about 20% and stays there fine.
The oil is topped off nicely, right in the zone its suppoest to be on the stick. There are no leaks that I can see and the truck leaves no oil spots on the ground.
Is my gauge going out or something more serious?
My truck is a chevy s10 1989 4x4 4.6 litre
Old 01-19-2009, 03:46 PM
496 BB is an unknown quantity at this point
Default RE: Oil Gauge is bobbing and drops to 0% in idle
I wouldnt trust a factory gauge any day. If you didnt take out the distributor then it should all be the same...given the oil pump is good and the shaft isnt broken/stripped. I would hook up a mechanical gauge and check it. If it tests out good it could be the oil sending unit sensor on the rear of the manifold. Or it could be your gauge as well but I think thats rare. I could be wrong bout the gauge though. Try it the other way first.
Old 01-19-2009, 08:31 PM
^^ +1
Put a mechanical gauge on it and see where it lies. Should be at a bare minimum 8psi at idle.
Old 01-20-2009, 08:55 AM
AEChevy's Avatar
Where can i get a mechanical gauge? And should I be worried that something is going to blow? This is my work truck, I dont want to drive it though if its gonna go out because of the oil lol [&:]
Thanks so much fellas for all the help and all my newby questions
Old 01-20-2009, 09:03 AM
You can get a mechanical gauge at pretty much any autoparts store. You will then have to adapt it to the 1/4" NPT hole in the block. If you get the appropriate t-fitting, you can put a mechanical gauge in with the factory oil pressure sending unit and leave it as is.
Old 01-20-2009, 10:19 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
Both of my trucks do the same thing, it gives me reason to get under the hood and check fluids more often.
Wincanton
08-07-2015 07:13 AM
c40788
03-23-2014 08:52 AM
abig84
14
06-07-2012 04:21 PM
RomanCatholic
11-09-2009 06:14 PM
ned4spd8874
03-06-2008 09:40 AM
Quick Reply: Oil Gauge is bobbing and drops to 0% in idle
