tranny type
Old 10-29-2012, 10:04 AM
coolcat0285's Avatar
coolcat0285 is on a distinguished road
Default tranny type
I bought an 89 blazer 4x4 4.3L v6 2 weeks ago since day one the tranny has been slipping, so from what i learned with everyones help. just replace it i'm guessing it's a 700/r4 but would like someone with more knowledge to confirm that before i go buy the wrong tranny. thanks
Old 10-29-2012, 10:16 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Its is indeed a 700r4.
Before you go looking for one in a junkyard remember this secret to compare if its a 700 or a 4l60e. If you look on the drivers side of the tranny,you'll see a big plug in. If its square its 700r4,if its round its a 4l60. If you are looking for one in a pull it yourself yard,only get one from a vehicles thats been wrecked,or you know for sure the engine is siezed. that doesnt mean you are getting a good one but the odds are more in your favor.
Old 10-29-2012, 10:25 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
700r4. Make sure to get another 4x4 trans. Dont try to convert. Not worth it. 4.3 shares the bellhousing with sbc's as well. Relatively easy to find.
Old 10-29-2012, 10:28 AM
chris015's Avatar
ah yes^
you CAN convert it but you MUST swap out the main shafts that run all the way through the tranny. its not as simple as swapping the tail. Man i wish it was. If you can swap these,you might as well rebuild the trans yourself as everything has to come out.
Old 10-29-2012, 05:16 PM
ohsofly's Avatar
Yup, make sure its from a 4x4. You can pull it from fullsize trucks as well...
Old 10-30-2012, 02:01 AM
will a 700 out of a 85 blazer 4x4 2.8 work on my 4.3 4x4
Old 10-30-2012, 07:10 AM
Nope. Different bellhouseing
Old 10-30-2012, 11:39 AM
neo71665's Avatar
Personally i would look for one out of a fullsize v8 over a v6 one. They are built a bit better. While you working on it put a trans cooler on it also.
60 (2.8, 3.1, 3.4)degree on left 90 degree (4.3, v8s) on right
Old 10-30-2012, 03:39 PM
trobbins's Avatar
dosen't one from a camaro fit also
Old 10-31-2012, 01:48 AM
neo71665's Avatar
Yall have many 4x4 camaros around your parts?
Quick Reply: tranny type
