SPark plug wire Nology
Old 01-24-2006, 12:18 AM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default SPark plug wire Nology
What have you heard about Nology Hotwires. I am thinking of getting them since I upgraded the ignition.
Old 01-24-2006, 08:11 AM
Default RE: SPark plug wire Nology
Ignition wires are such a joke. More than likely, you'll never out 'flow' the stock wires.
The core of stock wires is the same between my bonneville and my bravada. The wires on my bonneville have been proven to support 500chp and enough voltage passthru for a 0.055 gap with 16psi boost. If we (those of us in the 3800 community) can't outflow the stock wires, I bet you'd be hard pressed doing it on your blazer.
You have upgraded the weakest point already, the coil and ICM. Just use a quality stock wire and keep the rest of your money for other stuff.
Not to mention the amount of trouble that MANY people have had with aftermarket "HOT" ignition wires in general. The outer jacket of just about all of them is too soft and easily damaged. Once the outer jacket is comprimised, the wire is shot.
futuredoc
06-28-2010 02:50 PM
TruckeeT2
05-07-2009 09:26 PM
05blazer
10-11-2008 07:20 PM
boulonman
03-05-2007 05:10 AM
magnum434
Engine & Internal
17
08-17-2006 01:39 AM
Quick Reply: SPark plug wire Nology
