2001 Shift Solenoid issues
Old 11-20-2011, 11:42 AM
blazerdadbillykiker's Avatar
blazerdadbillykiker is on a distinguished road
Cool 2001 Shift Solenoid issues
I have a 2001 S-10 4wd Blazer that reverse gear stopped working.
At the same time, the check engine light came on and the error code says bad shift solenoid. I replaced both, flushed it and put in a new filter. Still doing the same thing and same error code. Any ideas?
Old 11-20-2011, 03:33 PM
pettyfog's Avatar
Which shift solenoid? May only be coincidence..
https://blazerforum.com/forum/2nd-ge...49/#post382707
https://www.google.com/search?q=blazer+no+reverse
Old 11-22-2011, 06:26 PM
I replaced both because it doesn't tell you which one. Have you had similar issues?
Old 01-06-2012, 07:22 AM
frmurphy's Avatar
frmurphy is on a distinguished road
Exclamation No Reverse on a 2000 blazer
Mine is doing same thing. I put it in reverse, and heard a "pop" and now no reverse. It goes forward fine, but now the check engine light is on and the code says its a shift solenoid also. But I am afraid its more than that because I have seen post where its the "Reaction Sun Shell" and transmission has to be taken out to fix. And it had this link http://www.justanswer.com/uploads/Bl...se_2nd_4th.pdf Is this true? If it is how hard is it to repair?
Old 01-06-2012, 09:56 AM
Gale's Avatar
Gale is an unknown quantity at this point
Remember the error codes DO NOT tell you what is wrong but ONLY the location of the sensor that set the error code. You often have to work upstream to find the problem that set the code.
It gets expensive swapping parts due to error codes readout only I have found.
dave5514
10-02-2015 10:20 PM
hitman2988
07-30-2012 03:05 PM
Tony H
01-21-2011 10:11 AM
Tony H
02-23-2010 08:09 AM
god_zilla00000
14
01-05-2010 05:26 AM
Quick Reply: 2001 Shift Solenoid issues
