Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Closed Thread
LinkBack Thread Tools Search this Thread
Old 06-03-2009, 06:40 PM
acf142 is an unknown quantity at this point
Question 95 blazer 4.3 hard starting and strong fuel smell?
hello my 95 is starting to act up a little some times it will start fine and other times it will crank and crank and then start with a strong "old gas" smell...best way I can explain it... I have smelled it before if it sits and idles for a little I get the same smell.... I'm thinking plugs but today I smelled coolant when I started it. I did just replace the heater core lines but that should have been gone my now I would have thought. I bought this truck used and the guy before replaced the motor and did not put the fan shroud back in so its missing and it has been getting a little hot sitting in traffic any ideas anyone?
Old 06-03-2009, 07:34 PM
ABN31B's Avatar
Send a message via Skype™ to ABN31B
Mine smelled like fuel at start up, at idle, and after shutting her off. Check your Evaporative Emission Canister. It should be under the driver's side rear fender.
**Edit, damn your a 95. EEC doesn't apply to you.**
__________________
Currently: Cooking up the last few mods before I come back.
Future Projects: Getting Active on this forum again...
Old 06-05-2009, 07:18 AM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Well for you I hope this is not your problem but I had the same issue and I just found out that my "spider" is bad (the fuel injection system), and its gonna cost me 400$ to fix. That all sounds like the problems I was having.
__________________
1995 Blazer 4.3L Vortec- Four Door 4X4
Just got my new spider injectors installed and all my problems are fixed!
Old 06-05-2009, 08:31 AM
rriddle3's Avatar
2012 Ford Mustang
I, too, would suspect the spider assembly, but a fuel pressure test (especially the leak-down portion) would tell more. You can use the 'search' function to find the instructions.
As for the coolant smell, you may have a partially plugged heater core. Do a thorough flush of it.
Old 06-05-2009, 08:47 AM
1974 Chevrolet K Blazer
My Garage
Send a message via ICQ to swartlkk Send a message via AIM to swartlkk
I would more suspect either a failed FPR or a leaking nut kit than an issue with the spider assembly as a whole. I am not saying that the spider assembly is not the issue, just that it rarely is the entire unit.
You sure will fix a fuel leak with a new spider assembly and new "nut kit", but you may be spending more money than you have to.
Old 06-05-2009, 10:16 PM
I got the 400$ for the new spider to get put in my truck, I feel like I should ask them to go over it again just to make sure thats it cause thats alot of money. Do my symptoms match it being a bad spider? Hard to start, very rough idle, very strong gas smell, drop of oil pressure when coming to a stop (when the bad idle starts)
__________________
Closed Thread
Tags
1995, 43, 95, blazer, chevy, crank, cranking, fuel, gas, hard, idle, leakdown, pressure, smell, start, strong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
