95 jimmy cutting out at 2krpm
So my 95 jimmy is cutting out at 2krpm and the abs light comes on. I unplugged all the abs and the light isnt on constantly but comes on once I start driving. I tested my fuel pressure at the rail. First time it was 10lb with the key on then 55lb when at idle. The secound time the on key was 60lb and the run pressure was 55 it dropped to 48 then I gave it gas. Could it be as simple as fuel pump or is it more likely the spider? Any help would be great.
You can throw parts at it, or you can diagnose it, (diagnosing is much faster and cheaper ) This link explains how to check the fuel delivery system: https://blazerforum.com/forum/2nd-ge...eakdown-88305/ Your 95 has the CMFI system, so you will need to use those specs. Post the results to all 4 tests and we can analyze them for you.
Well if you already "know" the fuel injectors are leaking then replace the spider. Not sure why you are asking us for ideas.
chcknugget
27
04-06-2018 07:42 AM
justDrivin
04-07-2008 06:13 PM
