Ignition switch no lights in dashboard Blazer would start
Old 01-03-2012, 07:09 PM
poertsch's Avatar
poertsch is on a distinguished road
Default Ignition switch no lights in dashboard Blazer would start
Hallo to everybody. I was searching the Forum and was reading a couple of posts about replacing and problems about the ignition switch. But before i will start to replace it i want your experience about this problem:
First at all it was begin with the problem that my transmission was only runs in security mode. So first I was thinking that i have a transmission problem. But i was checking everything and the solution was that the main power to the solenoid valves was only 6Volts. I was checking the wire diagram and see that the main power will comes over the ignition switch. So i was making an bridge from a free fuse inside of the fusebox an the transmission was working again perfekt.
After a while i was see that my Blazer was stopping in time when i was driving the motor by him self and i had to stop and start him again that he will work's. But now i had this problem again and now ,no Lights in the dashboard will come on. Also i here no fuel pump in time when i will turn the key. He want to start and nothing happens. No lights inside of the dashboard come up and my Blazer stays out of work.
So I think that to 95 % the ignition switch is damaged. Is this true or can it be also an another problem. Because Transmission, Lights in Dashboard and Fuel pump will get the main power before motor will start from the key. So what you think REPLACE the ignition switch?
For all your experience it will help me out.
thanks poertsch from Germany
Old 01-03-2012, 07:15 PM
pettyfog's Avatar
From that description and assuming you checked all fuses, and the ground points under the dash.. yes, I think ignition switch is likely bad.
Old 01-03-2012, 07:25 PM
poertsch's Avatar
I was also thinking about that, because in the main diagram i see that all necessary parts will get the Main-power from the ignition switch. I wrote that the Blazer was start and then after couple 1 Mile the dashboard lights come up and motor was stopped. So i have to stop put it on park and start it again. And than he was run but now he is in garage because he is only a summer driver and i was lucky that i drive him direct at home, when the last time the Blazer was stopping direct in the corner. It was taking me more than 20 times to get him start.
So i have to replace it. Is there an any description to replace it in point of my model 97 S10 that i can get an how do to do nothing wrong. Will help me out
thanks a lot
Old 01-03-2012, 07:27 PM
xgiovannix12's Avatar
there is a way to check the ignition switch thanks to our fellow administrator swartlkk
Anatomy of the Ignition Switch - Blazer Forum - Chevy Blazer Forums
Old 01-03-2012, 07:31 PM
poertsch's Avatar
Wow thats great will get me many information.
Thanks a lot and Forum is very very fast with answers Great job guys
Is there any step by step instructions to replace the switch. That i know what i have to remove that i can replace the switch. TThiw ill help me that nothing goes wrong in time of the replacing
Thanks poertsch from Germany
poertsch
03-04-2014 08:06 PM
bbkld5
01-31-2011 10:10 PM
robertabuck
11-29-2010 05:43 PM
Jebs99
10-03-2008 12:57 PM
DCFluX
10-05-2006 04:23 PM
Quick Reply: Ignition switch no lights in dashboard Blazer would start
