Heater shuts off on high
Old 02-14-2013, 11:06 PM
2004Blazerman's Avatar
2004Blazerman is on a distinguished road
Default Heater shuts off on high
I did all kinds of searches for heaters shutting off when it is put into the 4th(or high) selection. I have yet to find a thread that has this issue. If anyone out there has had this happen could you please post up what you did to fix it. I have a 2004 Blazer 4.3L 4x4. I have checked the fuses and all are good. Numbers 1-3 work fine but 4 shuts the heater down. There is nothing coming out of the vents at all on the fourth setting. Everything else works on the heater control panel. Thanks in advance.
Old 02-15-2013, 02:07 AM
Rumblur's Avatar
Rumblur is on a distinguished road
I've had this problem on a Dodge Dakota. It was the fan speed resistor. On the Dodge, it was mounted on the firewall, no idea on the location in the blazer.
Old 02-15-2013, 10:45 AM
grizzstang's Avatar
grizzstang is on a distinguished road
The fan speed resistor is usually mounted on the heater box with the coils reaching inside the box near the fan motor for cooling. Look for a plug near the fan motor that goes to a flat square with one or two bolts holding it in. Sorry I can't tell you exactly where either as I have not had to replace mine yet.
Old 02-15-2013, 03:41 PM
rexazz2's Avatar
generally when the resistor goes the fan only works on high
Old 02-15-2013, 04:04 PM
^ I agree. If high speed doesn't work, and all others do, the relay is most likely the problem. It has 5 terminals and is either in the underhood fuse panel, or close to the blower resistor, usually on the firewall. Wire colors are: Purple, black, 2 orange, (one slightly larger gauge than the other) and bark blue.
Old 02-15-2013, 09:01 PM
Thanks for the info, when I get time tomorrow, I will pop the hood and check voltages over the lines and see which one is bad then test the resistors. Thanks again everyone for the speedy response.
dachiphunter
08-04-2009 05:16 AM
rogggg1020
10-22-2008 09:15 PM
nitro
02-06-2008 11:37 PM
posjimmy
12-23-2007 08:35 PM
BOTTLEDZ28
13
11-17-2007 01:44 PM
Quick Reply: Heater shuts off on high
