4x4 wont switch!
Old 09-20-2007, 02:44 PM
gstclair83's Avatar
gstclair83 is an unknown quantity at this point
Default 4x4 wont switch!
I haven't posted on here in a while cause my truck was runing good. Knew it couldn't last too long. I have a 2000 LT 4x4, with the 4 buttons on the dash. When I try to switch from 2 hi to anything else, the button just flashes, but the 4x4 doesn't engage. IT worked fine a month ago, can someone please help?
Old 09-20-2007, 03:54 PM
blaze1002 is an unknown quantity at this point
Default RE: 4x4 wont switch!
That happened to my 01 when I first got it. One of the vacuum lines had disconnected. I'm no mechanic so yours could be something else, but that was my case. Good luck!!
Old 09-20-2007, 04:06 PM
hillbillyinOhio's Avatar
ORIGINAL: hillbillyinOhio
check the fuse first. sounds like a blown fuse to me. if it is a blown fuse, replace and try again. if it blows the fuse again, you need a new switch for the dash. usually around 50 bucks.
you other thread on same topic has been locked. please do not create multiple threads on same topics.
88Chevy
06-21-2012 11:53 AM
madmack4
05-24-2012 12:59 PM
cide
11-08-2010 08:17 PM
JediKnight2
09-11-2008 07:58 PM
gstclair83
09-20-2007 04:05 PM
Quick Reply: 4x4 wont switch!
