coils packs starting to go??
Old 06-30-2008, 06:06 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Default coils packs starting to go??
is there any signs that coil packs are starting to wear out and if so what are they and how quickly should they be addresed??
Old 06-30-2008, 06:18 PM
lfuller11's Avatar
lfuller11 is an unknown quantity at this point
Default RE: coils packs starting to go??
You might see some white arcing marks from either the wires, or on the pack itself.
Old 06-30-2008, 07:31 PM
You will start to get random misfires, worse while under load. It will get to the point where you won't be able to drive the thing because it won't be producing a hot enough spark.
Most often, the overmolded plastic case will crack due to corrosion on the coil stack.
thilly26
Headers, Intake, & Exhaust
09-05-2014 12:51 PM
jimmy1996
Performance & Brainstorming
05-03-2009 04:26 PM
CashSax
02-03-2007 06:07 PM
BlaZeR FXB1581
Suspension Tech
04-03-2006 02:52 PM
tayzoid1
02-22-2006 12:22 AM
Quick Reply: coils packs starting to go??
