lost ????
Old 11-23-2009, 12:33 PM
argon929's Avatar
argon929 is on a distinguished road
Default lost ????
i put some gabriel hijacker air shocks on the rear and it now noticeably leans to the front drivers side a good 2 inchs the air shocks are tied together with 40psi i measured the lenght of them at that pressure and there equal what would cause a lean? should i replace the front shocks also? any suggestions
Old 11-23-2009, 02:08 PM
sporty_drew's Avatar
Did you have any lean before?
Do you get any roll from them being tied together?
Old 11-23-2009, 02:43 PM
How much higher did you go with the back end?
Don't take this the wrong way, but the truck is sitting on flat level ground, correct??
Old 11-23-2009, 03:25 PM
argon929's Avatar
not takin wrong at all ya it was on level ground i even got a level to check the ground and it never leaned before what else is there that would cause that and the back is 1 inch higher than before on both sides in the rear and would it be better to run one line to each so there not tied together?
and another thing any idea where i can get the slide on nuts for the rear shocks mounts there cheap pos's and mine rusted out there for the top mount
Old 11-23-2009, 06:49 PM
It would eliminate the air from going from one to the other under compression.
Old 11-24-2009, 11:02 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
Torsion bars?
Old 11-24-2009, 12:56 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Use 1 air valve and run sep hoses to each shock.. make sure the hoses are not located near the exhaust or sharp metal..if you push down on your front fenders how much does the truck bounce when ya stop pushing on it? You could have a bad shock or even a broken spring..
Old 11-29-2009, 06:48 PM
argon929's Avatar
could i crank the t bar on the driver side? will that mess the the alignment up
Old 11-29-2009, 06:55 PM
Yeah you could and yes it would need to be realigned afterwards.
dougg01
Lifting Tech
19
01-21-2010 02:48 PM
wxj1974
01-03-2007 10:09 PM
NitrousJunkie
09-13-2006 05:13 PM
wxj1974
Nitrous, Super Chargers, & Turbos
08-05-2006 08:44 AM
rx7tturbo
12-04-2004 05:01 AM
Quick Reply: lost ????
