cant find rpo codes for rear diff 1996 blazer
i have a g80, and it's semi famous/infamous so it was easy to spot...
you may have to just write them down and decode away.
if you have "g80" then you have the G80 locking rear diff if it's anything else (open) i dunno what it is...
Your gear ratio will be a "G" something. GU6 is a real common one. It's for a 3.42 rear end. I see what you're saying thoigh. You want to know what rear end you have not just the ratio. Well... check this out. You are now hooked up.
http://www.c2e.info/rpocodes/gmrpocodesGthroughM.html
93LT
21
04-18-2017 07:49 PM
FireInMe17
01-02-2011 04:31 PM
