rear axle swap
Old 11-02-2008, 09:01 AM
luzznit's Avatar
luzznit is an unknown quantity at this point
Default rear axle swap
I have a 1999 blazier 4 w/d I broke a gear in the axle so i replaced the axle the gear ratio is the same gu6 was the code on the glove box. after i swaped axles out I have a vibration , so i jacked blazer back up and noticed that the drive shaft wobbles at axel end I know that there is 2 different types pf axles for that year 1 buffalo axel and the other i cant remember so I am thinking that the drive shaft dose not match the axle so my question is can iswap axle yoke out and that woulds take care of it or will the match
Old 11-02-2008, 09:06 AM
TripleBlackBlazer's Avatar
Default RE: rear axle swap
Have you tried rotating the driveshaft 90 degrees and reinstalling it? Give that a shot first.
Old 11-02-2008, 09:10 AM
luzznit's Avatar
ok i will try that real quick
Old 11-02-2008, 09:36 AM
luzznit's Avatar
okwell that seemed to help still have a small vibration at 55mph but that could be the tiers thanks for the help
2003_CHEVY_BLAZER
29
08-03-2013 02:05 PM
blajeans
01-09-2013 12:58 PM
LucasMI
01-02-2012 02:15 PM
OH_VDUB
Performance & Brainstorming
09-08-2011 09:13 PM
jmaynard
07-12-2011 01:03 PM
Quick Reply: rear axle swap
