Loud Roaring Noise Sometimes from Engine
Old 06-12-2009, 11:54 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default Loud Roaring Noise Sometimes from Engine
Ok so im notcing alot espically in these summer temperature that my truck will make a loud roaring noise from the engine. Example like when i start it and hit the gas it will be a loud roaring for a like 15 seconds then it will stop and will be fine. Today i drove about 30 miles and about the time i was getting home i was stopping at lights and everytime i stopped at one for a couple minutes and then starting going again there would be a loud roaring noise and then it would go back to normal. Is this a problem? If so how do i fix it? The noise is so obnoxious. I did do a search and came back with it might be a fan clutch? Ill do the test by trying to move the fan when the truck is cold tommorow morning.... Thanks so much
Old 06-13-2009, 12:03 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
That's exactly what it is, your fan clutch. Mine does the same thing. Roars first thing in the morning some mornings (silicone inside of it settled all to the bottom overnight) and when I'm hauling the karts on a hot day with the A/C cranked (doing it's job).
Old 06-13-2009, 12:09 AM
1998MSO's Avatar
1998MSO is on a distinguished road
Yes, that is normal. The owners manual for my 1998 even has a section called "engine fan noise" that describes what you posted as perfectly normal.
Old 06-13-2009, 12:51 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Old 06-13-2009, 01:32 AM
mech cb's Avatar
mech cb is on a distinguished road
Same here-annoying, but good.
Old 06-13-2009, 02:09 AM
bandidolenny's Avatar
It's hot man It's hot... got up to 107 here today. If your fan wasn't making all that noise then your engine would be overheating. It is normal.
Old 06-13-2009, 08:51 AM
midnightmekanik's Avatar
midnightmekanik is on a distinguished road
You find that annoying? I like it! My wife laughs at me when I do the Tim Allen oh-oh-oh grunt when it does that!
No but seriously, my pops has a Blazer, and it does the same thing. Mechanic says nothing wrong with it, just a normal noise.
Old 06-13-2009, 09:34 AM
truesmack's Avatar
truesmack is an unknown quantity at this point
Yeah, mine does the same thing, pretty normal, all of mine do it some, some worse than others thou.
Old 06-13-2009, 10:45 AM
cr8390's Avatar
hahaha ok good to no thanks everyone
Old 09-09-2009, 10:52 AM
chuckerchubby's Avatar
chuckerchubby is on a distinguished road
The Manuel says its normal but to keep your trans fluid cool. i thought i might put an auxiliary radiator normally used for keeping trans cool for towing hoping to reduce the number of times and length of time the fan clutch is activated
Quick Reply: Loud Roaring Noise Sometimes from Engine
