Rear Split Hatch won't open????
Old 11-06-2012, 10:29 AM
4x4blazerguy's Avatar
Question Rear Split Hatch won't open????
I did a search on this & if I read things correctly the only way to get the window open to make a repair is to break the inner panel. Is that correct? I have my 98 Blazer 4dr with a split rear hatch. The window opens with the button then you reach inside to lower the gate part. I can hear the actuator working when you push the button, use the button on the dash or key, but the window won't open.
Old 11-06-2012, 12:08 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Please let me know what you find out
Because I have the same problem with my 96.Thankx
Old 11-06-2012, 10:22 PM
Diaita's Avatar
Diaita will become famous soon enough
What if you pulled the tailgate hinge pins out and unbolted the helper spring? Could you then lift the glass and door assembly out enough to remove the screws for the inner panel? I haven't tried it, but maybe...
jakegaisser
06-08-2012 02:46 PM
bodnar720
03-24-2012 07:04 PM
Blake726
09-11-2011 05:56 PM
Major Tom
05-23-2011 12:34 PM
Kellen
09-21-2006 12:44 PM
Quick Reply: Rear Split Hatch won't open????
