Should I Flush Out The Radiator?
Old 05-22-2007, 01:00 PM
FemmeVamp's Avatar
FemmeVamp is an unknown quantity at this point
Default Should I Flush Out The Radiator?
My inlaws came by today cause I had what I thought was a coolant leak. They checked it out and found nothing wrong, but my mother in law put water in my coolant resevoir to see if it would run out [&:]...will that mess anything up? Do I need to flush my radiator now?
Old 05-22-2007, 01:09 PM
Default RE: Should I Flush Out The Radiator?
When was the last time the coolant was replaced in the vehicle? Also, what are we talking about here? Year, etc?
If the cooling system hasn't been serviced in a while, you'll probably want to do a full flush on the radiator, engine, and heater. Replace the thermostat and radiator cap. And clean the overflow bottle. Inspect the upper and lower radiator hoses for signs of deterioration and replace as necessary.
hroofblaze96
01-15-2020 04:39 PM
pfsantos
09-23-2010 03:58 PM
bigdaddykane93
01-04-2010 12:03 PM
portcqb
04-29-2008 09:56 AM
ZR 2
12-04-2007 03:53 AM
Quick Reply: Should I Flush Out The Radiator?
