Still Has a Rough Idle
Old 04-10-2008, 10:52 AM
GGA's Avatar
GGA
GGA is offline
GGA is an unknown quantity at this point
Default Still Has a Rough Idle
Here's a brief recent history of my 1996 4.3 vortec;
Rough Idle, 11 - 12mpg
[ul][*]Replaced Plugs, wires, distributor cap.[/ul]
Still Rough Idle,11 - 12mpg
[ul][*]Replaced Injection spider and regulator for updated MFI one along with O2 sensors.[/ul]
Still Rough idle, 14 mpg
[ul][*]Replaced EGR[/ul]
Still rough idle, now 16 mpg.
Can someone tell me what else I may be overlooking? The MPG should be around 17 - 18 mpg with a smooth idle (as it was when I bought it). I have ordered a vacuum guage to check there are no other vacuum leaks - this has a direct effect on the fuel pressure regulator and MPG.
The engine itself has good compression with no oil burning.
I know these are notorious for rough idles, I have gone through most things, if I can find out the problem then I may be able to help other Blazer owners. Is there anything else I am overlooking?
Thanks in advance.
Old 04-12-2008, 07:17 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Default RE: Still Has a Rough Idle
when you find out let me know...... i replaced EGR valve and still ruff idle. I'm doing fuel pump next
Old 04-12-2008, 07:56 PM
Thor, I would not recommend you change the fuel pump without first verifying that the fuel supply is causing the problem you are experiencing. But that is a topic for another thread.
GGA, do you experience this condition more when it is raining? What was the compression on each cylinder (list 1-6 please)? How did the plugs look? Was there any indication of which cylinder may be causing the misfire?
Old 04-30-2008, 05:18 AM
jmdrace is an unknown quantity at this point
do a simple pressure test on the exhaust . a clogged converter seems to foul things up and will give a misfire or rough idle .or if its not to rusted drop the exhaust just enough for it the breath.
Old 04-30-2008, 07:55 AM
Easier way of doing it is to pull an O2 sensor (disconnect it as well).
Old 05-01-2008, 10:15 PM
cpm0487 is an unknown quantity at this point
My Old Blazer had a similar idle issue due to the Throttle Position Sensor (TPS).
Old 05-09-2008, 04:48 PM
Clarkman325 is an unknown quantity at this point
Also make sure you installed correct plugs, OEM i know certain brands dont work well with the vortech.
Old 05-16-2008, 11:07 AM
chvygirl84 is an unknown quantity at this point
Mine too has a very rough idle. It gets worse the hotter the truck gets. haven't replaced anything yet as it JUST started this. It does seem to be worse in the rain though hmmmmmmm[]
Old 05-27-2008, 08:04 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
vaccum leak?
quick711
02-20-2012 05:30 PM
tim68
02-01-2011 08:39 AM
Sleazy_E
08-30-2010 07:34 AM
J_man01
Engine & Internal
01-13-2007 10:03 PM
Mbastet99
16
04-24-2006 02:37 AM
Quick Reply: Still Has a Rough Idle
