Stuck in 4 low
Stuck in 4 low
Hi, I have a 95 blazer 4x4, the 4 low was pressed while it was in park or drive.(not sure which one)....now it wont shift out of 4 low, we have checked actuator and vacuum hoses, any ideas???
thank you
Teresa
thank you
Teresa
I have tried everything everyone said and still nothing, the fellow that did this to my truck said he got in and started it and just pressed all the buttons......4hi,4lo and 2h..a bunch o times
I just went out and tried the rocking, it didnt work, and now if I press 4 hi or 2 hi there is no clicking or nothing,
is there a fuse that controls any of this stuff, I noticed I dont have any wipers either
If you have lights on the dash, then the 4WD fuse should be good (it's called '4WD' in the IP fuse block).
Try disconnecting the battery and see if it will allow you to shift back into 2HI after you reconnect it.
yeah they aren't cheap, transfer cases aren't any cheaper. try what kyle said first
