Removing Remote Keyless Entry RKE Module
Old 08-01-2007, 02:34 AM
paulf707's Avatar
paulf707 is an unknown quantity at this point
Default Removing Remote Keyless Entry RKE Module
Hi all
I've read a number of posts on here saying that if you've got the wiring for the RKE module, all you need to do is plug it in....
Does this mean that if I want to remove this, I can just unplug the RKE module? Will this completely disable the Immobiliser? or will it just leave my Blazer immobilised with no way of getting it running again!
My problem is I've only got one remote fob, which really doesn't work very well. I can't get a replacement fob for it that works, and I'm worried if the fob fails, I'll be left immobilised without anyway to get the Blazer running again....
I've got a 1999 UK model (RHD) Blazer.
Thanks
PaulF
Old 08-01-2007, 08:00 AM
hillbillyinOhio's Avatar
Default RE: Removing Remote Keyless Entry RKE Module
you can remove it, but all the RKE does is lock and unlock your doors. the immobilizer is in the key head and the ignition .so, as long as you have your key, you will be fine.
Old 08-01-2007, 08:13 AM
Yup, what Pat said.
But you should be able to find replacement remotes online... All you need to do is match up the FCCID on the back of the remote with the new remote and reprogram them when the new ones get there.
Old 08-01-2007, 11:13 AM
paulf707's Avatar
The more I look into this, the more I find out the UK Blazers seem to be very different to the ones you guys have in the US
The Imobiliser is not in the key - I now open the doors using the key (as the remote only works from outside approx. 20% of the time), but I still have to press the unlock button on the fob before the Blazer will start.
There is no FCC ID on the fob, the only number is GM/UTA 15732810
I found a website that seemed to suggest that this related to FCC ID:KOBUTIBT, but I tried a new fob with this number but that wouldn't work. I then found someone else who could supply a fob with GM/UTA 15732810 on the back, but that wouldn't work either. I now believe that the reprogramming routine is different for the UK models - I think you need the 5 digit security code (which I don't have) to program a new remote.
Chevrolet UK only have 1 dealer who is authorised to work on these vehicles, and he's over 200 miles away.....
I (stupidly) assumed that now Chevrolet cars are more common in the UK, I wouldn't have any problems with the Blazer, but it seems these were originally imported by the Vauxhall garages - but as they're not imported any longer, the Vauxhall garagesdon't deal with them. When I speak to the Chevrolet dealers, most of them haven't even heard of a Blazer, and certainly can't do much with them.
chevyman93
03-11-2013 05:23 PM
ComputerNerdBD
10-16-2011 06:10 PM
cr8390
12-26-2008 09:11 AM
MOTORSPORTS 1
12-15-2008 02:38 PM
Quick Reply: Removing Remote Keyless Entry RKE Module
