Bear's 95 jimmy
#51
Time for a posi lock upgrade
#52
Yep, Rex is correct. I've seen a couple guys do it and, when done correctly, it gives you a flawless positive lock. If I can ever get out of doing maintenance on my 2000 and start doing some mods, that is one I will do for sure. Check the first page of Rex's build.
#53
Well before I do any of that I was driving and I noticed I had no breaks... So I left it in a field and i'm going to see if I can get it to my house somehow... I will be doing the break lines very soon...
#54
Hey i noticed the ontario plates where abouts are you in ontario?
#55
#56
So I got another TPS for my jimmy, has to be the third one now... As soon as I put it on I start it and the sensor breaks in to 3 pieces... Time to get another one...
#57
Hi I've got a crack on the end of my radiator, could you refer me to where you bought the plastic resouivor? its on the right side of it i tried epoxy and stuff but still got a leak :/. The used auto wrecker wanted $150 for a USED radiator that I would have to remove myself!
