wiring harness 350 chevy
Old 12-08-2007, 12:03 PM
mojoman13's Avatar
mojoman13 is an unknown quantity at this point
Default wiring harness 350 chevy
hey so im in the middle of my 350 swap into my 4x4 86 blazer and i was wondering if anybody makes a wiring harness for a carburated 350 that would work for my application because i really dont want to have to deal with this mess
thanks!
Old 12-08-2007, 09:01 PM
Default RE: wiring harness 350 chevy
So you are going from a TBI motor to a carb'd motor? You shouldn't need much of anything by way of wires for the carb'd motor and should be able to make up your own harness pretty easily. The difficulties would come if the ECU is tied in to any other systems on the truck. The ECU won't like not having inputs from the O2 sensors and other components that feed it data.
Have you checked out the JagsThatRun.com website for suggestions?
Old 12-08-2007, 10:19 PM
Blazin_Jason's Avatar
I've seen some harnesses but I can't recall where from. Like Kyle said, since we are going carb'd it's easier. Are you wanting to use the stock gauges? I know I want to, and I think I have most of that figured out.
Old 12-08-2007, 11:11 PM
mojoman13's Avatar
well i was told im not going to need the ecu at all anymore since i'm going carbed and i changed the gas tank from internal fuel pump to mechanical fuel pump.
and ya i was planning on keeping the stock gauges but does that pose a problem?
i sent my wiring harness to my uncle the mechanic and he didnt really have any clue of which wires to take out and which to keep.
i was hopingsomeone just made a simple harness to save me loads of time
i'll check in my jtr book again to see wat they suggest
phxjosh
10-30-2013 10:03 AM
tech180
02-02-2013 10:23 AM
2001_chevy_blazer_owner
03-11-2012 05:54 AM
tomwill454
07-13-2010 06:21 PM
88s10Blazer
02-04-2010 04:19 PM
Quick Reply: wiring harness 350 chevy
