No overdrive sometimes????
Old 05-07-2011, 05:03 PM
4x4blazerguy's Avatar
Smile No overdrive sometimes????
I'm starting to have a problem with my transmission in my 97 Blazer 4x4. Yesterday I was headed home from a 1500 mile trip. About half way home it wouldn't go into overdrive. then it would sometimes. I stopped it & restarted it a couple of times it would work for awhile then not. Sometimes I noticed if I had to slow down or stop that it would sometimes BANG one/two shift. After a few hundred miles of acting up it threw a code. The last time I had a code, I had it checked it was something like torque converter trying to lock up or something like that. The shop made reference to a switch or something. I say that because it was over a year ago & I can't remember yesterday.
Any ideas?? I was thinking it is electrical like a switch or module. Fluid if FULL & clean. I have a B&M SuperCooler on it.
Thanks in advance.
Old 05-08-2011, 08:54 PM
I guess I'll have to run the question by a transmission shop in the morning & see if they can shed any light on this issue. I drove it a 100+ miles today & it worked flawless.
Old 05-09-2011, 07:20 PM
Took it to a transmission shop today & described what it was doing as I did here & they told me it was the most common problem with 93-04 Blazers. They even knew what code # when I told them as I did here. So it will be fixed Wednesday. Thanks
Eric S
03-18-2012 07:12 AM
novaman66
03-21-2011 08:19 PM
byrm31
12-07-2010 08:29 PM
Todd525
11-30-2008 05:54 PM
Blazer1305
Engine & Internal
12-04-2005 09:52 PM
Quick Reply: No overdrive sometimes????
