1995 Chevy blazer 4.3 stalling and not staying running.
I have a 1995 Chevy blazer with a 4.3 with the spider injector. To start with it has a new distributor cap rotor wires and I'm sure new spark plugs and new fuel pressure regulator. Egr has been cleaned and there are no vaccum leaks. The car runs OK when first started up but after driving for a little bit it starts lunging jerking and rough acceleration. When I slow down and stop the car stalls and takes a minute to start back up. Sometimes after it stalls I can get it to crank back up but then it dies again. I can keep it running for a few seconds by pressing the throttle then it dies. I'm leaning towards bad iac. Has anyone experienced this issue.
1995 used 2 different fuel injection systems, and 3 different computer control systems. Diagnosis procedures and specs are different, so we need to know what you have. Does your distributor cap look like this:
Or like this:
Or like this:
The best way to test a converter for restriction, is using a pressure gauge in the oxygen sensor mounting hole forward of the converter. As an alternate, you can remove the sensor and test drive it. Be aware that it will blow very hot exhaust out the hole, we don't want any fires
sowellj22
05-26-2015 09:50 AM
GeneralBlazer
07-11-2014 02:18 PM
evanrobinson1985
07-06-2013 02:01 PM
dbgrif95
09-16-2009 08:48 PM
wayne1979
05-11-2009 04:38 PM
