1999 blazer no fuel getting to carb
hi.. I had the fuel pump replaced and I can hear the fuel pump running and also the pump fuse relay.. I replaced the fuel filter and still nothing. I just removed the fuel filter to see if fuel would come out of the line but nothing.any suggestions would be appreciated. thanks
Thanks for replying...I saw the mechanic install it as for wiring im not sure.. Would i have to drop the tank to determine this and also how would I determine this..im not to mechanically inclined..looking forward to your response..thanks again
Sometimes if wired backwards the pump will pull a suction against your finger at the output line - I have also seen the pressure line off the pump not being securley clamped and it will blow off, kinked lines ect. also with the tank cap removed you might hear bubbles or fuel being sprayed
bryson_horton
11-03-2011 10:23 AM
bryson_horton
03-03-2010 08:22 PM
