2008 Trailblazer oil pressure guage at zero but driving fine?
I have a 2008 Chevrolet Trailblazer LTZ 5.3L V8 140,000 km. Two days ago when I started the car and began driving, I noticed the “Check Gauges” light had come on and the oil pressure gauge needle was exactly at 0. I immediately stopped my car and shut down the engine to check the oil level which was absolutely fine. I wasn’t sure what to do, so I carefully drove to my destination without any problem. There was no engine power issue or any other noise. There was no engine oil warning light or any message like “oil pressure low” on the driver information center. Everything seems to be fine except the “check gauges” light and the oil pressure gauge reading. I have driven more than 300 km since then. What should I do?
Get the pressure checked. you should have done that right away. If you actually have no oil pressure and you drove for 300 miles your engine is toast. It may simply be the sending unit but you must get the pressure checked regardless.
the86ali
TrailBlazer GMT360/GMT370 (2002-2009) Tech
04-19-2015 10:54 AM
castnhope
03-05-2012 05:10 PM
JasonT
06-29-2010 04:10 PM
bulldogauto
06-11-2010 07:43 PM
thisspaceforbrent
10-14-2009 12:57 PM
