350 sbc wont shut off :/
I had the carb rebuilt and my acceleration problem is solved!
But now, when i turn the truck off, it keeps running, i unplugged the battery, and spark plugs, and fuse box, the engine still kept running.. What in the world?? Help!
How long does it stay running? I've had old cars "diesel" from carbon buildup before. Usually it's only for a few seconds, seven or eight at the most. The carbon heats up, and acts as a source of ignition to keep burning fuel, and keep the engine turning for a second or two, although pretty crappily sounding, and mostly in front of all the cool kids at your high school...
The only times I've had an engine continue to run were when I used Seafoam. It would be breaking the carbon loose which would have more exposed surface area allowing it to pick up more heat and continue to run until it used up the residual fuel in the intake runners.
Yes Seafoam will help but you're going to need to do it a few times and really beat on it between cleanings to remove as much carbon as possible each time.
chester92
11-14-2011 02:50 AM
