cranks but wont start
Old 09-18-2008, 02:08 PM
josh05's Avatar
josh05 is an unknown quantity at this point
Default cranks but wont start
cranks wont start getting a p0336 code replaced crank sensor still no start help
Old 09-22-2008, 12:21 PM
Default RE: cranks but wont start
I have the P0336 diagnostic procedure ready to post, but due to forum problems, I have not been successful.
I cannot read through the diagnostic procedure right now, but will do so when I have a chance and comment further at that time.
*EDIT* - Have you checked the ECM 1 (15A) fuse? If the fuse is good, you should check continuity from the fuse to the pink wire at the CKP sensor. If that checks out, then you need to check continuity between the yellow wire and pin 31 (yellow wire) on the PCM C1 (blue connector) this is the 3x CKP sensor signal. Next check would be the purple wire at the CKP sensor connector to the purple wire at pin 28 on the PCM C1 (blue connector) this is sensor ground.
Straka88
09-19-2011 07:27 AM
chevyokie
08-21-2011 04:38 PM
bsbob
07-22-2011 12:48 PM
nyjeepman
34
03-15-2009 07:40 PM
91Blazerblk
09-16-2006 02:25 AM
Quick Reply: cranks but wont start
