Distributor Replacement
Hi All
I have a 2005 that I am going to replace the distributor on. Can I:
Mark the position of the rotor
pull the existing dist
remove the sensor
install sensor on new dist
replace rotor in correct position
install new dist
button it up!
The engine will not be turned over. So am I correct in doing the above without bringing the engine to TDC?
Thanks
remove the sensor
install new dist
button it up!
Thanks
LannyL81
04-18-2013 09:50 AM
