Help broke down on a trip
I am trying to do this on my phone so please excuse any typo's.
Short story - drove from Indianapolis to Chicago without issue. Left convention center to go back to hotel and noticed oil pressure fluctuating from 40 to 0 and back at highway speed. Jumped off toll road in a bad area and quickly put 2 quarts in because the change oil light came on a couple of weeks ago and I figured that was the issue. Also, I wanted to hurry and get to the hotel. Oil pressure still fluctuating - Oops probably too much oil now. Pressure dropped to 0 most of the way back - 10 miles. Temperature never moved so I kept going. Got to hotel and it kinda sounds like a diesel. Is that from too much oil? Any ideas? I read that sending unit could be the culprit. No tools with me but AutoZone will probably let me use some if I get the unit there.
Thanks for any advice.
Chuck
Chuck
Yes, I checked the oil on the dipstick. It was very dark and hard to see. I put in one quart and tried to get back on the toll road. The pressure continued to fluctuate. I pulled over in a very rough part of town, quickly poured in another quart and got out of the asap. My wife was in the car. I kept driving with the 0 reading because I really had no other choice. The truck was running just fine and the temperature never rose.
Thanks for the help.
yeah those are common, if you had no oil pressure your engine would have been knocking almost instantly. i used to own a blazer that had 30psi upon cold start and would go down to zero slowly over the course of 20 minutes so i always drove it at 0 oil pressure for years, never cared about the gauge
[QUOTE Got to hotel and it kinda sounds like a diesel. Is that from too much oil? [/QUOTE]
This part of his first post kinnda bothers me. No I wouldn't think too much oil would cause a diesel sounding rattle, inless maybe its way over full and the crank it wiping it into a foam, not good for the motor tho in any terms - Makes me wonder if the oil pump isn't on its way out also.
thenewguy
03-01-2010 01:40 PM
FemmeVamp
12-07-2006 09:17 PM
