Low oil pressure 20psi at idle
Old 03-30-2012, 01:38 AM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
Default Low oil pressure 20psi at idle
i just changed my oil last week and my oil pressure is staying at 20 on idle and it goes to 40-41 psi at 2000 rpm. what can i do to get the psi right
it is a mix of 5w-30 and 10w30. 2/5 and a stp filter.
Old 03-30-2012, 02:25 AM
97cherryblazer's Avatar
97cherryblazer will become famous soon enough97cherryblazer will become famous soon enough
If those numbers are when the engine is warmed up then thats fine.
What is the PSI when the engine is cold?
Old 03-30-2012, 03:06 AM
red06sc's Avatar
red06sc is on a distinguished road
seems about like mine also. i want to say mine is around 80psi on a cold start.
Old 03-30-2012, 05:26 AM
I hope you mean 60
Old 03-30-2012, 05:32 AM
pettyfog's Avatar
Context, please.. what was it before the change? How long have you had the truck? How many miles on odo? Did you have the LIM gasket fail? Or was it before you bought it?
And what is it at cold start, 1000 rpm?
Old 03-30-2012, 09:29 AM
red06sc's Avatar
Originally Posted by 97cherryblazer
I hope you mean 60
i do lol
Old 03-30-2012, 12:03 PM
the oil pressure stays the the same at 20 cold or hot. 168000 miles
had her since august of 2011 and the LIM gasket seams fine to me. the dealership did the motipoint inspection and he found evidence a oil leak but my oil levels do not drop. many be a past leak?\ and the pressure was the same before the change. cold rpm is at 1000-1200
Old 03-30-2012, 05:23 PM
rriddle3's Avatar
1. Until you hook a mechanical oil pressure gauge to the engine you don't know for certain what the pressure is.
2. What was the purpose in mixing the two different viscosity ratings?
Old 03-30-2012, 06:38 PM
pettyfog's Avatar
I agree. If the mechanical gauge says the same then you can go from there
Old 03-31-2012, 06:35 PM
autozone did not have the right viscosity thay only had 2 10w and 3 5w on sale
jdiaz
09-26-2023 11:29 PM
lost113
12-11-2011 06:08 AM
musclecar70sfan
09-30-2010 06:58 AM
noom14921992
11-09-2008 05:16 PM
s10_1997
03-28-2008 02:30 PM
Quick Reply: Low oil pressure 20psi at idle
