multiple random missfire
Ok new to the forum and I know this has been mentioned a number of times and I did look through the forums and found nothing. The issue is a po300 code that started last week driving to work. Long story short fuel pressure is good and holds, compression is good and holds. So far parts that have been replaced consist of spider injector, fpr, wires, plugs, cap and rotor, and distributor but yet problem still exists. What baffles me is when I pull wires from the distributor (5,1,3) no change in idle as well as fuel dumping out the exaust. When in the vehicle you can definitely feel the missfires. Can somebody please point me in the right direction.
Double check the seal where the spider comes through the upper plenum. these are known to leak vacuum if they do not seat correctly. i had to use a lubricant on my new seal when I replaced mine to get it to go down all the way.
KidBlazer
02-07-2013 11:08 AM
