timing ends up at 12 deg. advance
Old 10-22-2014, 05:53 PM
G ELLIOTT's Avatar
G ELLIOTT is on a distinguished road
Default timing ends up at 12 deg. advance
Got 02 4.3 RS2 just got done putting heads on it. Shows im at 12-14 degrees advance. Seems to have a slight spark knock and a bit lazy. Anyone have experience with this problem.
Old 10-22-2014, 05:56 PM
Did you set the CMP Retard to zero after installing the distributor (details in the Tech Article section)?
Old 10-22-2014, 06:02 PM
G ELLIOTT's Avatar
No I didn't. Sorry to be a pain if the information is already here I'm new to your site obviously. And to this truck. Thanks for your response.
Old 10-22-2014, 06:13 PM
Check out the EDI Engine Timing thread in the Tech Article (DIY) section. The index of this section is linked to in my signature below.
Old 10-22-2014, 06:23 PM
G ELLIOTT's Avatar
Right on I just read it. Didn't think that bracket was sloppy enough to get 15 degrees but will have try that first. Dont have scanner that smart. Or do you disagree with that line of thought.
Old 10-22-2014, 06:44 PM
You'll need a scan tool to accurately set the CMP Retard to zero. The only other way is to trial and error it until its running better. Even then, you'll want to get it on a capable scan tool to get it as close to zero as possible as premature cam & distributor wear can occur with prolonged run time off zero.
Old 10-22-2014, 06:54 PM
G ELLIOTT's Avatar
Will do. Thanks for your time
Old 10-23-2014, 07:39 PM
G ELLIOTT's Avatar
Thats much better thanks again.
wierdo124
09-02-2013 07:38 AM
Doctorvette
11-05-2012 11:57 PM
Bake
Performance & Brainstorming
02-04-2012 10:31 PM
4x4VegasDan
06-19-2010 10:54 AM
JustBlaze!
01-16-2008 05:00 PM
Quick Reply: timing ends up at 12 deg. advance
