99 Blazer
99 Blazer
Changed both frt hub assemblies,now my ABS is very sensitive (summer).ABS never engaged in summer now coming to a normal stop can feel ABS,hit the brakes real hard ABS really comes on.
Is this normal ?????
Thank You
Thank You
What brand did you go with for the hub assemblies?
Sounds like one or more of your WSS are just putting out too low of a voltage when the wheel turns. You can test the mV-AC output. It needs to be above 250mV. If it isn't, you can file down the mounting surface on the hub assembly.
Either that or you could return it for one that works.
