Gas Meter not accurate
I have a 99 blazer and i just want to know which is more accurate, the analog meter on the dash or the digital reading on the module on the roof. Because when i get the low gas light the analog points to empty but the digital readout still says i have like 150km left. I just want to know because in the summer i was getting around 425km for a full tank of gas but now i'm get 320km soabout a100km less.
RE: Gas Meter not accurate
How much fuel are you putting in when you are on E on the dash gauge?
usually varies, usually around48 - 51 litres but yesturday idrove until thedigital readout said only 90km left and it wentup to 55 Litres.how many litresdo you normally get on empty?
My 'low fuel' light comes on when I have 3-4 gallons left in the tank. That gives me ~60-80 miles of driving left.
I wish I had a gas guage [&o]
On a related note, if the fuel sender dies, will the overhead console give the correct range? I would think so, since the sender just supplies a level to the guage, not a quantitative volume of fuel used. Is that right?
The console works off of an algorithm based on the average miles per gallon and the distance traveled, knowing the capacity of the tank. The problem with that is if you are driving more aggressively or less aggressively, your actual mileage may be very different from your average (depending on when you last reset it).
How do you reset the overhead thing? and if my dash meter is correct on the low fuel is there any reason i would be losing about 100km of gas? I don't drive very hard, i change my oil about every 8,000 km with mobil 1 high mileage synthetic, i have a k n N drop in filter and i put a new cat the only thing bad on my truck is my tires, there pretty bald.
ORIGINAL: MacK
How do you reset the overhead thing?...
ok cool thanks, last question does anyone know how many litres a 99 4x4 blazer can hold for gas? i heard it holds 18 gallons so that's about 68 litres i think but i want to know if that's true or not.
2 door = 19 gallons
4 door = 18 gallons
4 door = 18 gallons
J.R. Clay
03-07-2011 08:03 AM
93LT
05-17-2006 06:06 PM
