Unusual green coolant reaction? Knowledge, please?
As manager and o.s. saleswoman for a local Auto Parts Store, I was calling on a customer today when he pointed at the 55 gal. drum he uses to hold his antifreeze. He purchases concentrated green by the gallons, and combines with water in the drum. 3/4 full, the antifreeze looked to have separated. A pale pastel green color at the bottom, and a darker more 'normal' looking at the top. I've never seen this, They ARE NOT using distilled water, but would that cause this severe of an issue within a matter of wks/days? I can't get my supplier (Shell oil) to return calls. Any thoughts on this?
What was in the barrel before antifreeze? Are you sure it isn't just an optical illusion looking through the water? I know if Dexcool got mixed in it would be brownish, & look like sludge.
Wow... Nothing of the sort really considering that most "green" coolants now have a very similar base with different additives... But that's for another thread. How about we leave the Dexcool right out of this discussion.
Well I appreciate all the input from you guys. I finally did talk to a tech rep from Shell Oil and he tells me that this is exactly what antifreeze does even in the radiator, just that we're not aware of it because we can't see it. Said it wouldn't make a difference if distilled water was used or not (although they recommend deionized and not distilled anyway), and just to give it a little stir to blend the 2 and create the solution. Thanks again!
This has caused me to want to do a little experiment... Ill be back in a half hour.
EDIT:
Here we go, Ive set up 6 bottles, nobody is going to shake them, and Ill watch them over the next weeks and see if they separate or whatever may happen. I dont have a bottle of water handy, so Ill grab one, top up those 2 on the end, and shake them all again tonight. I can do more bottle combinations if theres any other ideas. Any predictions?
EDIT:
I can't wait to see what happens!
Why couldnt you be around when i had science pojects to do?
Chances are your little science experiment won't do anything as the coolant is just sitting in a plastic bottle and not circulating through a rad and block that are rusty in side. If you buy premixed it isn't separated or sludgy in the plastic jug.
and the same thing applies to the drum. how can you see the seperation line?
i'm also wondering why it was never noticed before, if indeed this is nornmal? (according to Shell)
You can see how the green & dexcool are dark green almost brownish. It you get them mixing in a warm rusty or metal environment they all will change some more.
My reference to Dexcool is reference to any of the new antifreeze's used in these aluminum engines. If you are dealing with a 96 or newer GM product your dealing with Dexcool.
My 97 still has a little of the aftermath of once using Dexcool then being switched before I bought it. They never got out all the brownish/green sludge on the walls of the reservoir. The rest of the system is clean I did end up changing out the radiator it had that same sludge in it not very much but enough to notice.
