TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
03 trailblazer front vibration
Old 10-06-2014, 01:18 PM
KeithPS's Avatar
KeithPS is on a distinguished road
Default 03 trailblazer front vibration
I'm chasing a front right side vibration/hum that gets louder to a groan on left turns. I've already replaced all the obvious, front right wheel bearing hub (twice), front right CV axle, and the 4x4 disconnect assembly. Ive also swapped the tires around and the vibration is still there. I'm outta ideas, anything you guys can suggest would be much appreciated. Thx.
Old 10-08-2014, 11:30 PM
tsmith1156's Avatar
tsmith1156 is on a distinguished road
I just had the same problem, when I turned right it was like a metal on metal grinding and I had to replace both the right and left front wheel hub assemblies and bearings
Old 10-28-2014, 09:29 AM
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
I would do the left. My hubs seems to be bad on the side I am turning toward when the noise increases oddly enough.
Does it vibrate all the time?
Is the diff fluid in good shape?
Old 10-28-2014, 05:01 PM
TMM217's Avatar
TMM217 is on a distinguished road
Ive had this similar issue for quite some time too. Ive narrowed it down between the half shafts and output shaft on TC. Im wondering if it the bearings in the axle itself.
Old 10-29-2014, 07:31 AM
KeithPS's Avatar
Got to the bottom of it. Replaced the right side hub/bearing assy again along with the upper ball joint which was totally shot and still had a vibration so went ahead and replaced the same on the left, ball joint not as bad but needed a new one, and that did the trick. No more vibrations. Now on to the TPS problem, but that's another thread. Thx for the help.
Old 03-09-2015, 08:50 PM
TMM217's Avatar
Sorry to bring up an old thread. Im thinking my inner axle bearings may need replaced. I do have a small leak at seal on right tube where cv axle goes in.
Is anyone have info on replacing those bearings? I believe there are 2 bearings in the tube.
Old 03-11-2015, 10:18 AM
HARDTRAILZ's Avatar
You have a Blazer or Trailblazer?
On my Trailblazer...I have done the seal on the DR side and rebuilt the disco on the PS side with new bearings and such.
Old 03-11-2015, 02:39 PM
TMM217's Avatar
Sorry I posted in wrong section. But yeah I have a 2nd gen blazer.
ZR2Driver
01-21-2010 03:08 PM
wGraves
10-28-2009 06:50 PM
SanfordBlazer
02-27-2009 07:49 PM
miso
13
01-02-2007 10:20 AM
keeskc
06-06-2006 03:07 AM
Quick Reply: 03 trailblazer front vibration
