Torsion Bar Crank Tutorial
Old 07-15-2014, 08:57 PM
Sept0922's Avatar
Sept0922 is on a distinguished road
Default Superlift ballpoint relocation
Hi I'm new on here. I have a '99 blazer zr2. I turned the torsion bars up. Now people say only go 1-1.5 inches because bj and cv angles...what if I buy the 1.5" superlift upper control arms from summit...? They are designed to take the angles out of the ball joints. Is doing that a good idea since I've cranked up torsion bars??? Also doing the rest of front end for alignment with new cv shafts
  #22
Old 07-16-2014, 09:50 AM
El_Beautor's Avatar
The new upper control arms would help for the ball joints, although I personally don't have any experience with them. That won't help at all with CV axle angles though. You might be better off going with something like the Rough Country 2.5" lift which includes new upper control arms as well as a drop bracket for the front diff to address the CV axle angles.
  #23
Old 07-20-2014, 03:49 PM
Sept0922's Avatar
Default Diff drop
Now I want to stick with the upper control arms from summit because ball joints bolt in. Should I just order the diff drop separate from the kit so the cv angles are better
  #24
Old 07-20-2014, 05:02 PM
newguy's Avatar
Cant get the kit separately
  #25
Old 07-21-2014, 09:22 PM
Sept0922's Avatar
Default Diff drop
Just called rough country and the diff drop kit is $55 with $6 shipping. So the trucks getting rough country diff drop, napa premium half shafts, superlift upper control arms, moog heavy duty upper ballpoints as long with lowers, and urethane lower control arm bushings...any thing I missed? All steering related components are great. Do I get a sway bar drop kit?
  #26
Old 07-21-2014, 09:24 PM
Sept0922's Avatar
Should I order the add a leaf kit separate and then get some lift shackles?
  #27
Old 07-22-2014, 04:07 AM
newguy's Avatar
Hmmm this is new
  #28
Old 07-22-2014, 11:52 AM
Sept0922's Avatar
He sounded kind of hesitant to tell me over the phone.
  #29
Old 12-22-2015, 08:42 PM
TMM217's Avatar
TMM217 is on a distinguished road
Anyone know the max ride height (distance from center of wheel to fender lip) when doing a torsion bar crank with the RC kit?
CraigSnedeker
Lifting Tech
05-15-2011 08:18 PM
Duram98jimmy4x4
Suspension Tech
03-19-2011 07:18 PM
appstateblazer
03-04-2010 09:39 AM
tt0876
Suspension Tech
05-05-2008 11:32 AM
Bgray
Suspension Tech
09-10-2006 04:45 PM
Quick Reply: Torsion Bar Crank Tutorial
