Some dash lights wont turn off after LED swap
Old 03-04-2012, 09:31 PM
rgwoehr's Avatar
rgwoehr is on a distinguished road
Default Some dash lights wont turn off after LED swap
Last weekend I replaced most of the bulbs in my instrument cluster with LED's. They all work fine but the airbag, ABS, and parking brake lights never completely shut off, they stay on but are dim. I used the same bulbs in the turn signals, high beams, service engine, and check gauges and those all work properly. How can I fix this? Thanks in advance
Old 03-25-2012, 06:22 PM
20xtreme03's Avatar
20xtreme03 is on a distinguished road
Default there off
its not that the bulbs on its prob that the leds are so bright there lighting up that part of the gauge also. what bulbs did you use an how many did u replace? im planning on doing mine you have any other pics?
Old 03-25-2012, 06:46 PM
xgiovannix12's Avatar
might be bad sockets just an idea
I dont know if that for sure is your problem
Old 03-26-2012, 07:47 PM
rgwoehr's Avatar
The lights were still on during the day when the illumination bulbs weren't on. I had to take it apart today because the service engine soon light was flickering and then went out, so I just swapped the problem bulbs out with regular bulbs from the old cluster.
I bought the bulbs on eBay in 10 packs, they were 194s and 74s I think. There are 5 194s in the cluster and I don't remember exactly how many 74s there were but 10 wasn't enough.
Old 03-29-2012, 03:38 AM
r0k0's Avatar
r0k0 is on a distinguished road
LED will only work on 1 side, if they dont turn on take it out and reinstall them with a 180 degres turn, should work
r0k0's Avatar
Old 03-29-2012, 06:46 PM
03Xtreme's Avatar
03Xtreme is on a distinguished road
How many bulbs are needed too light up just the #'s and the oul, gas,temp and battery?
Old 03-30-2012, 12:45 AM
Thogert's Avatar
For an 03 you will need 6 194s (or T10s)
Old 03-30-2012, 10:16 AM
03Xtreme's Avatar
Are they all the socket lights?
Old 03-30-2012, 10:58 AM
Thogert's Avatar
Yes, you will need to find the sockets for them. GM decided to weld the stock bulbs in them so they are a pain/impossible to reuse. You can usually find them in junkyards.
Quick Reply: Some dash lights wont turn off after LED swap
