Power mirrors, temp read out not working in 1999
Old 02-02-2016, 12:17 AM
Joshua_D's Avatar
Joshua_D is on a distinguished road
Default Power mirrors, temp read out not working in 1999
So, I just bought a 1999 Chevy Blazer. It's in really good shape, but the power mirrors, and temp read out aren't working, I checked the fuse and it's good. I'm not getting anything from the mirrors. No sound, movement at all.
Thanks in advance.
Joshua
Old 02-02-2016, 07:02 PM
Joshua_D's Avatar
So, I fixed the power mirrors. After reading a few posts, people kept talking about the switch. I took out the switch, took the switch apart, cleaned the circuit board and contacts with electronic cleaner, put it all back together, and bam! Power mirrors work again.
Old 02-03-2016, 12:32 AM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
Is the display not lit of the temp or are you just not getting a reading? If no reading you will need to replace the sensor which is located behind the grill. Pretty easy swap out.
Old 02-03-2016, 05:51 AM
Joshua_D's Avatar
AJBert, the temp is not lit up at all.
Old 02-03-2016, 11:55 PM
AJBert's Avatar
Is the compass part lit up or the whole thing out? If the whole thing is out then it is either a power issue or the unit is kapoot. If the compass part is working then the sensor for the temp needs replaced.
Old 02-04-2016, 07:18 AM
Joshua_D's Avatar
Nothing is lit up, no temp, no compass, nada. I'm guessing that it's kapoot. Going to pull it out today and see if any connections are obviously broken.
Old 02-12-2016, 09:51 PM
Joshua_D's Avatar
I bought a used overhead console off eBay. Works like a champ.
Old 02-12-2016, 11:46 PM
AJBert's Avatar
Glad to see you got a working one!
Old 02-14-2016, 11:18 AM
Joshua_D's Avatar
Me too!
vcampsteam
01-24-2011 10:30 PM
kickme005
07-10-2010 10:07 AM
shibbershabber
02-21-2010 12:43 AM
fresno99
07-31-2009 08:12 PM
DaddyCop03
05-11-2008 09:07 PM
Quick Reply: Power mirrors, temp read out not working in 1999
