Screwed the pooch, 94 Olds Bravada AWD
Old Jun 1, 2009 | 08:34 AM
Those small rod like things sound suspiciously like rollers from a needle bearing... If the output shaft support bearing was down a few rollers, that would allow the shaft to be able to drop and open up a leak... That does not sound good!
Pictures will confirm what those things are. If there is play in the output shaft, I would say the bearing is bad... Also, if you have access to a vernier caliper, measurements from the output shaft to the bottom of the seal bore and from the output shaft to the top compared with each other would also confirm whether the bearing is bad.
Old Jun 1, 2009 | 07:41 PM
82 Iron Duke's Avatar
82 Iron Duke is on a distinguished road
I'm fighting a small battle here, I finally found a seal today and fubard it putting in the shaft I think I am just going to have to replace the diff since I already have half of it apart. I also found metal shavings in the front diff so now I need to go to the jy and hope I find a diff. It's my understanding that all these will work:
OLDSMOBILE BRAVADA 1996 Front Axle, 3.73 ratio (opt GT4)
CHEVY S10 BLAZER & GMC S15 JIMMY 1995 Front Axle, AWD, 3.73 ratio (opt GT4)
CHEVY S10 BLAZER & GMC S15 JIMMY 1996 Front Axle, AWD, 3.73 ratio (opt GT4)
OLDSMOBILE BRAVADA 1991 1992 1993 1994 Front Axle, 3.73 ratio (opt GT4)
GMC SAFARI (GMC) 1990 1991 1992 1993 1994 1995 1996 Front Axle, 3.73 ratio (opt GT4)
CHEVY ASTRO VAN 1990 1991 1992 1993 1994 1995 1996 Front Axle, 3.73 ratio (opt GT4)
So now I am going to do some reading to see how hard it is to replace it
Old Jun 3, 2009 | 09:17 PM
Just in case anyone is interested I replaced the seal and so far I haven't smelled any burning oil yet. I was not able to locate a front diff at any of the yards so I just put it back together and am hoping for the best. The overall removal process was easy, I didn't need any special tools except for the 36mm socket and the breaker bar which I was able to borrow. If in fact the diff decides to go I know I have the ability to replace it. My fingers are crossed that it is fixed, to be continued, maybe.
Old Jun 3, 2009 | 09:37 PM
Sounds like a plan. Thanks for the follow up.
Old Jun 9, 2009 | 03:33 PM
jspafford's Avatar
jspafford is on a distinguished road
Sure as heck looks like a crack to me. I would pay close attention to it. No sense in replacing the seal and hoping it's not cracked because you don't want to deal with it if it is.
Old Jun 12, 2009 | 06:47 PM
The whole thing looks like that, very bad casting. Well it's still leaking so now to find a front diff, JY doesn't have one right now
Old Nov 16, 2009 | 07:29 PM
Update:
I have since bought me an 04 Silverado but still have the Bravada. I went to the JY today and found 2 Jimmy's, one is a 95 and the other is a 97. Both have the correct gearing GT4 now here is the question before I pull the part. Does it matter if the donor diff comes from an AWD or a 4X4? I don't think it does but I have to be sure.
Old Nov 16, 2009 | 09:35 PM
It does. The passenger side axle prop shaft on an AWD is a single piece shaft and there is no front axle engagement mechanism.
You could take the center section of the diff and swap the passenger side axle tube and prop shaft from your axle with relative ease though. The center sections are the same.
Old Nov 17, 2009 | 09:36 AM
Thanks for your help, I think I can manage the swap.
97Bravada
Aug 12, 2012 08:38 PM
blavada
Dec 20, 2009 08:13 AM
acfiero
Mar 12, 2009 09:41 AM
NC93BLAZERLT
21
Dec 30, 2008 05:23 PM
93LT
Jan 9, 2006 09:25 PM
