2002 Chevy Trailblazer
Old Aug 11, 2007 | 03:06 PM
betsihook's Avatar
betsihook is an unknown quantity at this point
Default 2002 Chevy Trailblazer
I just had a front headlight go out so I replaced it. When I first put it in both lights worked fine, now my low beams don't work at all. I checked the fuses and everything is ok, any suggestions??
Very frustrating!!
Old Aug 12, 2007 | 01:59 PM
Default RE: 2002 Chevy Trailblazer
Fuses 3 & 6 (10A) in the underhood fuse block should be the left and righ headlamp fuses, respectively. The other things that the headlights have in common are their voltage feed through the HDM Relay in the underhood fuse block. This relay supplies power to the low beams for DRL and normal headlight functions.
Old Aug 21, 2007 | 01:57 PM
*Moving to Gen Tech - GMT360 Tech*
Any updates on your problem? Do you need additional information?
FBH1992
Jan 14, 2012 11:45 PM
jrpx2
Jul 8, 2010 02:02 PM
mboggess
Jul 16, 2008 09:00 PM
lionel2
Feb 23, 2008 07:25 PM
brian101798
Jan 11, 2008 10:46 AM
