4X4 Issue
Old Apr 9, 2009 | 10:46 AM
Duckman562's Avatar
Duckman562 is an unknown quantity at this point
Default 4X4 Issue
I have a 2000 Blazer LT 4X4.
I have kind of a weird issue with my 4X4. As of now, my "Service 4X4" is lit up on the dash and my lights to switch from 4-Hi to 4-Lo ect. are not lit up. On occasion I will be driving or start up my car and the "Service 4X4" will turn off and my lights with turn on, and I can shift into 4X4 just fine, but then it will go back to not working at random times. Any idea what this might be? A loose connection somewhere?
Thanks!
Old Apr 9, 2009 | 12:00 PM
Definitely sounds like a loose connection. I have seen the connection at the back of the switch come loose part way and cause this issue. I would start there. If that does not cure the problem, then have a look at the connection on the TCCM (behind passenger side kick panel) and the encoder motor (side of the transfer case) for signs of corrosion.
Old Apr 9, 2009 | 03:51 PM
Duckman562's Avatar
Thanks, I;ll give those a try. To get to the back of the switch, do I just need to remove the dash panel?
Old Apr 9, 2009 | 05:25 PM
The small panel the switch is in should just pop out if I remember correctly.
Old Apr 9, 2009 | 05:38 PM
Duckman562's Avatar
I popped out the switch on the panel, but all the connections look good. Where is the passenger side kick panel, and how do you remove it?
Old Apr 9, 2009 | 05:40 PM
It is the panel under the dash on the side. I cannot remember exactly how it is removed, but I think it just pulls off as well. Look for screws first though.
Old Apr 9, 2009 | 05:48 PM
Duckman562's Avatar
Strange, I took off the kick panel and all the connections look okay. I'll have to mess around with it some more and see what I can find.
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
camino88
Jan 7, 2010 12:51 PM
extreme
Jan 5, 2010 07:29 AM
