Reverse Issues
Old Nov 19, 2009 | 03:00 PM
TT's Avatar
TT
TT is an unknown quantity at this point
Default Reverse Issues
Hi All - My 96 Jimmy pretty much doesn't go in reverse. I've read some posts in regards to the sun shell. I have all forward gears, though. For a good while it rarely would go at all in reverse. Now it engages at times, but never cold. What do you think?
Thanks - Tom
Old Nov 19, 2009 | 06:47 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
can you give us a little more info... is it 4X4 etc, If you have all of your forward gears I doubt it is the sun shell, if it was the sun shell you would not have 2nd or 4th... it could be your reverse clutch pack, you sure you have all forward gears, not just 1st and 3rd??
Old Nov 19, 2009 | 07:38 PM
TT's Avatar
TT
I'm sure that it has all the forward gears. It is a 4x4. It's got 170,000 miles, but I've only had it for the last 40,000 so I don't know any repair history in regards to the transmission. Not sure what other info that would be helpful.
Thanks for the reply - Tom
Old Nov 19, 2009 | 07:46 PM
Nvidia78's Avatar
have you checked the fluid level with it hot after driving it, is it full on tranny fluid... does the fluid smell burnt at all??
Old Nov 19, 2009 | 08:50 PM
TT's Avatar
TT
Tranny fluid level is and was OK. It was pretty dirty, but didn't smell burnt. I drained off around a quart and replaced it with new about a month ago. It does seem to engage a little more frequently since.
Old Nov 19, 2009 | 09:24 PM
Here is the symptom related checks:
Old Nov 20, 2009 | 01:05 PM
TT's Avatar
TT
Old Nov 20, 2009 | 09:10 PM
TT's Avatar
TT
Any thoughts for which are most likely and the cost. Probably not anything that I'd tackle.
Tom
Old Nov 21, 2009 | 05:33 AM
Nvidia78's Avatar
I would take it to a transmission shop in your area, they are able to do a variety of pressure tests and then they can recommend what needs to be done... you can then go from there
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
msfan324
Dec 4, 2009 01:40 PM
megaroos_00
Jul 31, 2009 10:26 PM
