97 blazer no spark
Old Aug 26, 2010 | 01:02 PM
truck317's Avatar
truck317 is on a distinguished road
Default 97 blazer no spark
so i picked up this 97 blazer for a buck and i cant get it started. I replaced the coil wire and i still had no spark. so i looked under the blazer and i found that the plug that does into the cam shift crank sensor was bad so i replaced the plug and still have no spark. i hooked a test light up to the negative side of the battery and check the plug that goes into the coil and the test light lit up. then i hooked the test light up the positive side of the battery and i tested the plug and the i had no light from the coil plug. so whats the problem. the blazer has been sitting for over a year. im trying to find another coil to see if thats the problem
Old Aug 26, 2010 | 01:07 PM
Ryanmatt135's Avatar
take your test light and hook it up to the two wires going to the coil, while holding the test light there, have a friend crank the vehicle over, if the test light flashes then your circut is good and you need a new coil, if not it could be a number of things. test it first and then tell us what you find
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
jerickso
Apr 13, 2006 02:24 PM
