Just a battery issue?
Old Aug 26, 2010 | 12:18 AM
Tortex53's Avatar
Tortex53 is on a distinguished road
Default Just a battery issue?
The weirdest thing happened today. I got done replacing my fuel filter. I started it up, and it cranked a while until it got fuel and then it started up just fine. I reparked it, shut it off, and then I decided I should probably check for leaks. I turned the key while the door was still open and it made a clunk as it started to engage the starter and then everything went black: no dome light, no warning lights, absolutely nothing. I took the key out and then tried it again and there was not a sound or even the faintest light. I went back out after about an hour and the dome light came on and the warning lights came on, but when I went to crank the engine it did the same clunking sound and then everything went completely black again. I checked the voltage at the battery and it read 12.7. It seems like since there was voltage, at least the dome light or the warning lights would show dimly or something, but there was nothing. Not even a click when turning the key. Any thoughts on this? Is there some sort of master relay or something that I can check. I haven't had a chance to get the battery tested, but it seems like it might be something more!
Old Aug 26, 2010 | 08:53 AM
helo's Avatar
helo is on a distinguished road
your battery terminals/connectors are corroded or loose. Make all the contacts shiny with a wire brush. Replace stripped side-post retainer bolts if needed. I'd bet your battery is fine.
Old Aug 26, 2010 | 01:31 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
^ X2 ^ loose battery connections cause weird problems on these trucks. but it wouldnt hurt to go down to your local parts store and have them test the battery and alternator for free.
Old Aug 26, 2010 | 01:45 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Agreed, try cleaning/tightening your battery cables first.
1998mom
Jul 25, 2013 09:43 AM
TigaHotty85
Jun 17, 2013 03:10 PM
chevyman93
Dec 17, 2012 05:59 PM
tnw912
Jan 5, 2010 05:27 PM
ste
Aug 8, 2006 03:19 PM
