Front End Shimmy
Old 02-27-2008, 05:29 PM
bigswetty's Avatar
bigswetty is an unknown quantity at this point
Default Front End Shimmy
Hey Guys. When I'm going down the road, when the motor is at a specific RPM range the whole front end of the truck shakes. IfI speed up, this goes away. I rotated my tires, and it didnt help.
Old 02-27-2008, 11:08 PM
94blazer4.3ho is an unknown quantity at this point
Default RE: Front End Shimmy
first what year of vehicle, motor, 4x4? automatic transmission?
when they rotated the tires did they balance the tires? what speeds are the vibrations accuring? if you still have discover tires i would start with them!! j/k they're alright
Old 02-28-2008, 06:46 AM
D 5UPE is an unknown quantity at this point
Does it happen while in 4 W/D?
Also check your brake rotors for warpage, and check your pistons in the brake calipers.
Old 02-28-2008, 03:24 PM
bigswetty's Avatar
Its a 91 Fullsize K5 Blazer with a 350 TBI with an auto trans. 4wd too.I rotated the tires myself, and i didnt balance them. The vibrations occur at around 40-50 mph. Also, i checked the rotors and they dont seem too bad. They arent warped. And as for when its in 4wd, Im not sure because i dont drive the truck on the road in 4wd at all.
Old 02-28-2008, 05:18 PM
drperry's Avatar
Try going that fast when not in overdrive and see if it still does it...
Old 02-28-2008, 05:45 PM
bigswetty's Avatar
It doesnt do it when im not in overdrive. It only does it when the motor is at a certain RPM in overdrive.
Old 02-28-2008, 07:40 PM
drperry's Avatar
Probably something with the torque converter, then...
When was the last time the transmission fluid got changed?
Old 02-28-2008, 08:23 PM
bigswetty's Avatar
NOt sure. I got the truck in October. And I didn't change it. So god knows how long its been since its been changed, the guy i bought it from didnt even put it on the road...
Old 02-29-2008, 05:35 AM
drperry's Avatar
Could be something to check...
Especially if it only happens when the torque converter kicks in.
Old 03-03-2008, 02:23 PM
vinniej is an unknown quantity at this point
I had a Monte Carlo that did that (shook when the converter locked up),we replaced the converter, and the lock up solenoid and I never could get it to quit. Hope you have better luck.
Coco808
07-08-2011 12:00 PM
Fast Rider
22
04-29-2011 03:38 PM
Marine1975
10-31-2010 11:38 AM
ZR2Driver
01-21-2010 03:08 PM
bellert
08-19-2009 05:52 PM
Quick Reply: Front End Shimmy
