Clunking noise when turning... Wheel bearing???
Old 02-05-2010, 11:20 AM
mkbermel's Avatar
mkbermel is on a distinguished road
Default Clunking noise when turning... Wheel bearing???
I'm not sure what this could be... It clunks when I turn either direction. It seems fine if you're going straight though... If you're going around a turn it kind of waves I have no clue how to explain what's happening.... I was thinking either wheel bearing/hub assembly, ball joint, or sway bar... so in other word have no clue. A couple people I've talked to have leaned toward wheel bearing but want a couple more opinions.
Old 02-09-2010, 03:03 PM
brad_blazer's Avatar
brad_blazer is on a distinguished road
If its four wheel drive and one of the 2nd gen ones it is your cv axles in the front. Repalce them and you should be fine. Normally sway bars wouldn't make that sound. Hub assemblies would make noise all of the time most of the time when they go out.
Old 02-09-2010, 05:11 PM
A broken sway bar end link could definitely make a clunk when you turn.
A failing wheel bearing typically is not described as a clunk. More of a hum (slightly bad) to a growl (really bad) which would be more noticeable when turning at first, but gradually get more noticeable while going straight as well.
When CV axles go, they typically will click/tick while turning.
Is it a rhythmic clunk, consistent with your speed or is it random?
Old 07-11-2010, 10:41 AM
Namtaru's Avatar
Namtaru is on a distinguished road
sorry to bump this thread, I just bought a '97 blazer that is experiencing this same issue.
What this ever resolved op?
Old 07-20-2010, 12:05 AM
Namtaru's Avatar
in case anyone cares, i got a chance to lift the front of my truck up (it SUCKS living in Chicago, you aren't allowed to work on your truck anywhere )
After rotating the wheels back and forth while off the ground it was easy to see that my front right CV halfshaft was very loose, and ended up needing to be replaced.
the part was $60 from autozone and was replaced in a few hours
all is good!
Old 07-20-2010, 08:03 PM
wlorton's Avatar
I think this is my issue...... Mine is rhythmic sounds like its a record player wobbling... if that makes any sense....
jobiscomplete
12-05-2012 04:48 PM
ComputerNerdBD
08-30-2011 10:59 PM
NEW YORK BOY
04-10-2011 09:06 AM
ComputerNerdBD
Tires and Wheels
03-05-2011 05:50 PM
S10Blazer
11-09-2007 08:08 PM
Quick Reply: Clunking noise when turning... Wheel bearing???
