rear chatter
Old 04-20-2015, 05:38 PM
64sschevelle's Avatar
64sschevelle is on a distinguished road
Default rear chatter
Well I can't decide if it is rear end noise or ujoints....it starts at about 10mph. ..and gets louder with speed ..it can let off the gas and it quiets down some and when I put foot back on the pedal it's louder....here is a video. If you can get passed the interior rattle. You can hear a humming /clicking sound...sounds like rear passenger side to me.
https://youtu.be/xit7XlkZR2g
Old 04-20-2015, 06:29 PM
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
Sounds just like mine did when two teeth broke off of the pinion gear.
You could check for play in the U-joints and if all seems tight with the joints then I suggest you jack stand the Blazer as I did and then use a mechanics stethoscope to listen at the rear differential cover for the sound in the video, if it's coming from the diff. then pull the cover and look for broken teeth in the bottom of the diff. housing, also inspect the ring and pinion teeth for damage by turning the rear wheel by hand which will rotate the ring and pinion gears.
I remember that project like it was yesterday
The ole switcharoo, broken toothed open diff. to a boneyard locker rearend.
Old 04-20-2015, 06:54 PM
What I was afraid of
e602
91
03-08-2015 04:53 PM
rockp2
12-01-2012 10:16 PM
Buck731
10-01-2012 09:47 PM
bombadee
07-10-2009 07:13 PM
bluesjam99
02-18-2007 08:24 PM
Quick Reply: rear chatter
