Help???
Help???
OK, I have to start with a confession? I don't own a Blazer
I have a 2002 Olds Bravada. My first plunge into GM four wheel drive. I thought I was getting the deal of the century when this was offered to me.
But???? 2 inches of snow and I can't get out of my driveway? I have always had Jeep products. Simple transfer cases and differentials. This Smart Track AKA whatever Chevy calls it is baffling me. I'm here because the Bravada forums only get hit once a month of so???
The front axles are not engaging, I thought that if I spin one wheel the other should spin the other way? I can manually turn the front drive shaft from under the truck and the front wheels do not engage?
Not Upset, just begging???
I read about a (Special) Blue transfer case fluid that will solve all my problems???? But if the front differential isn't engaged to the drive shaft how can that help?
Is there a Blazer equivalent to the Bravada Smart Track?
If the Bravada is the same setup as the Blazers then locking of the front axle is via a vacuum actuator. So first off....check the vacuum lines under the hood. Start at the engine and follow the lines and replace as necessary.
If all is good there, then check the vacuum actuator under the battery tray. You can pull on the wire cable which will engage the front axle unless there is something broken within the front diff.
Try these things and then come back with what you find-out.
OK, So I am playing Dad and Mom this week so, not to much time for the truck. I drained the transfer case and disconnected the battery. According to Advance Auto I was supposed to use 3 pints of fluid. I put in 2 quarts of AC Delco's (Auto-Trak II). Pricey stuff! I still cant feel it through the inspection hole? I call to confirm pints and not quarts. No, they insist it is 3 pints? Does any here know how much of this blue gold I have to put in?
