1990 GMC Jimmy 1500 Idle problem
Old 10-24-2011, 11:12 PM
wollefdoog's Avatar
wollefdoog is on a distinguished road
Thumbs down 1990 GMC Jimmy 1500 Idle problem
first of all im getting a code 44. i have changed the tb GASKET, removed the exhaust except the catalitic converter, cleaned the electric terminals and changed the O2 sensor. The truck will barley start and then dies after about 15 seconds uinlesss i spray starter fluid down the intake.. is this fuel pump , vac problem, fuel pump, or a combo of all three? It stsrted when i was going down the road and it stsrted to surge and i was able to nurse it back home by feathering the throttle. I thought bad gas, but addatives did nothing..any ideas?
Old 10-26-2011, 10:35 PM
Chzyrider's Avatar
Chzyrider is on a distinguished road
Here is a GM 44 code definition and typical causes, hopes this helps in eliminating the possibilities.
CODE 44
Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin.
The conditions for setting this code are:
  • no Code 33 or Code 34 (MAF Error) present, and
  • the O2 sensor voltage remains below 250 mVolts, and
  • the ECM is in Closed Loop control, and
  • the above conditions exist for more than 50 seconds.
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) MAF sensor reading lower airflow than is actually present
7) Vacuum leaks
8) Incorrect or poorly calibrated PROM
Old 10-26-2011, 11:10 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Sounds like fuel pump to me....Do a fuel pressure test at the inlet of the fuel filter...should be 10-13 psi.
Old 10-27-2011, 10:59 PM
wollefdoog's Avatar
Thanks guys..it ended up being the fuel pump..amazing..It actually shows 14 PSI now..lol
Old 10-27-2011, 11:13 PM
chris015's Avatar
Cool...i gotta ask...what brand pump?
Xb-lineblazerX
01-23-2012 09:03 PM
acc62001
07-21-2011 07:20 AM
jeepjunky
06-24-2011 09:55 PM
pothole987
10-05-2010 07:35 PM
eddiep23
06-18-2010 11:11 PM
Quick Reply: 1990 GMC Jimmy 1500 Idle problem
